跳转到主内容
Casio Exilim EX-Z80 LCD Screen Replacement
你所需要的
  1. Casio Exilim EX-Z80 LCD Screen Replacement, Back and Front Cover: 步骤 1 中的图像 1,3 Casio Exilim EX-Z80 LCD Screen Replacement, Back and Front Cover: 步骤 1 中的图像 2,3 Casio Exilim EX-Z80 LCD Screen Replacement, Back and Front Cover: 步骤 1 中的图像 3,3
    • Remove the four 3 mm black screws from the bottom of the camera using a Phillips #000 screwdriver.
    • Open the battery compartment with your thumb or index finger.
    • Remove the single 2 mm silver screw that is now exposed using a Phillips #000 screwdriver.
  2. Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 2 中的图像 1,3 Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 2 中的图像 2,3 Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Open the USB port tab.
    • Remove the single 2 mm silver screw using a Phillips #000 screwdriver.
  3. Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 3 中的图像 1,2 Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the two 2 mm silver screws using a Phillips #000 screwdriver.
  4. Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 4 中的图像 1,2 Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Carefully remove the silver strip from left side. Open the battery cover and remove the metal strip with fingers by sliding it to the left.
  5. Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 5 中的图像 1,2 Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 5 中的图像 2,2
    • With the metal spudger, pry out the edge of the silver strip at the bottom right side of the camera.
    • Carefully remove the remaining part of the metal strip.
  6. Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 6 中的图像 1,2 Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Remove the two 2 mm silver screws from the top corners of the camera using a Phillips #000 screwdriver.
    • Remove the three 2 mm screws from the left side using a Phillips #000 screwdriver.
  7. Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 7 中的图像 1,3 Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 7 中的图像 2,3 Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Using a small opening tool carefully release all lock tabs at the top and on the side of the camera from their locked position.
    • Using your hands, carefully separate the front and back panel from the camera.
  8. Casio Exilim EX-Z80 LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 1,3 Casio Exilim EX-Z80 LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 2,3 Casio Exilim EX-Z80 LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    • Gently flip the wide button cable up from the display cable.
    • Lift the brown retention flap on the display cable ZIF connector with tweezers or an ESD-safe tool.
    • Carefully pull the display cable from its connector.
  9. Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 9 中的图像 1,3 Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 9 中的图像 2,3 Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 9 中的图像 3,3
    • Pry the square holes that hold the LCD screen up with a metal spudger until you see the raised tabs in the metal holes.
    • Repeat the process with the holes around the four edges of the camera.
    • Insert the metal spudger into the gap of the metal case and pry up the LCD screen.
  10. Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 10 中的图像 1,3 Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 10 中的图像 2,3 Casio Exilim EX-Z80 LCD Screen Replacement: 步骤 10 中的图像 3,3
    • Hold up the LCD screen in one hand and hold back the button cable with the other.
    • Don't let the LCD screen to fall back into the metal case and make sure the button cable does not get stuck on the display cable.
    • Pull on the LCD screen until the yellow display cable is fully out of the metal case.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 35
总计 666
