配件
无需配件。
Use a pair of tweezers to gently move the wire away from the lens
  • Use a pair of tweezers to gently move the wire away from the lens
  • This will make the area around the lens easily accessible
添加评论
The lens is held in by two hooks, one in the upper left hand corner and another in the lower right
  • The lens is held in by two hooks, one in the upper left hand corner and another in the lower right
  • Using a screwdriver push the metal hooks on the upper left corner, underneath the edge of circuit board. Pull up on the upper left corner of the lens, freeing the corner from the camera casing.
添加评论
  • While pulling the lens up out of the casing, push the hook to the lower right corner of the lens out of the way.
  • At this point the lens should be connected to the camera solely by two orange plastic strips.
添加评论
  • Using tweezers or finger nails pull up the brown flaps where the two orange film strips connected to the lens meets the circuit board.
  • Use tweezers to pull the orange film strips out of the port. It should come out easily.
  • There are two additional film strips connected to the circuit board that do not need to be removed. These are connected to the opposite side of the circuit board than the lens.
添加评论
  • Completely remove the lens. There should not be anything else holding it in place.
添加评论
  • Turn the lens over
  • On the back are four screws. Remove the two silver screws (4.36 mm) from the back of the lens.
添加评论
  • Remove the loose piece from the back of the lens and set it aside
  • The lens is now ready to be replaced with a new one.
添加评论
结论
另外一个人完成了本指南。
Dylan Fuller
于2012年04月12日注册
101 信誉积分
撰写一个指南
团队
Cal Poly, Team 17-28, Amido Spring 2012 Cal Poly, Team 17-28, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G28
4 名成员
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 584
