配件
无需配件。
  • Open the battery door by sliding it toward the LCD screen.
  • This will reveal a small screw to the left of the memory card slot.
  • Carefully remove the screw (1.77mm).
  • The bottom panel of the camera will become loose. It is connected to the camera by two wires so do not remove completely.
添加评论
We have oriented the camera with the lens up and the flash toward you for clear visibility. Use a pair of tweezers to gently move the red and black wires away from the lens.
  • We have oriented the camera with the lens up and the flash toward you for clear visibility.
  • Use a pair of tweezers to gently move the red and black wires away from the lens.
添加评论
Using tweezers or finger nails to pull up the brown flaps where the three orange film strips meets the circuit board. Use tweezers to pull the orange film strips out of each port. Be sure to do this to all three orange strips. They should come out easily. Use tweezers to pull the orange film strips out of each port. Be sure to do this to all three orange strips. They should come out easily.
  • Using tweezers or finger nails to pull up the brown flaps where the three orange film strips meets the circuit board.
  • Use tweezers to pull the orange film strips out of each port. Be sure to do this to all three orange strips. They should come out easily.
添加评论
  • Pull the circuit board away from the camera.
  • Be careful the circuit board is still attached to the camera by a black film strip.
添加评论
  • Gently pull off the plastic cover over the LCD screen
添加评论
  • Gently pull the LCD screen away from the camera. Be careful since the screen is still attached to the camera circuit board.
  • You have now completed the guide to remove the the LCD screen.
添加评论
结论
Jenn Eberts
于2012年04月10日注册
200 信誉积分
创作了2篇指南
团队
Cal Poly, Team 17-28, Amido Spring 2012 Cal Poly, Team 17-28, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G28
4 名成员
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 4
总计 290
