跳转到主内容
Casio Exilim EX-Z70 Battery Replacement
  1. Casio Exilim EX-Z70 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Casio Exilim EX-Z70 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Casio Exilim EX-Z70 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Orient the camera with the lens facing to the right and the bottom of the camera facing up towards you.
    • Grasping the camera tightly, press downward firmly on the piece with the label and slide it to the left (towards the LCD screen).
    • The flap will then swing upward.
  2. Casio Exilim EX-Z70 Battery Replacement: 步骤 2 中的图像 1,2 Casio Exilim EX-Z70 Battery Replacement: 步骤 2 中的图像 2,2
    • With the battery now exposed, pull the dark gray tab away from the battery.
    • The battery is no longer secured in the camera.
  3. Casio Exilim EX-Z70 Battery Replacement: 步骤 3 中的图像 1,1
    • Firmly grasp each side of the battery and pull it out of its compartment.
结论
3等其他人完成本指南。
Jenn Eberts
于04/10/12注册
277 声望
撰写一个指南
团队
Cal Poly, Team 17-28, Amido Spring 2012 Cal Poly, Team 17-28, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G28
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 46
总计 4,756
