跳转到主内容
Casio Exilim EX Z55 Motherboard Replacement
你所需要的
  1. Casio Exilim EX Z55 Motherboard Replacement, Front Case: 步骤 1 中的图像 1,3 Casio Exilim EX Z55 Motherboard Replacement, Front Case: 步骤 1 中的图像 2,3 Casio Exilim EX Z55 Motherboard Replacement, Front Case: 步骤 1 中的图像 3,3
    • Remove eight 1.8 mm screws from the left and right sides of the camera using a Phillips #00 screwdriver
  2. Casio Exilim EX Z55 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the four 3.7 mm screws from the bottom of the camera using a Phillips #00 screwdriver.
  3. Casio Exilim EX Z55 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Separate the front case from the body of the camera.
  4. Casio Exilim EX Z55 Motherboard Replacement, Back Case: 步骤 4 中的图像 1,1
    • Separate the back case from the body of the camera.
  5. Casio Exilim EX Z55 Motherboard Replacement, LCD Screen: 步骤 5 中的图像 1,3 Casio Exilim EX Z55 Motherboard Replacement, LCD Screen: 步骤 5 中的图像 2,3 Casio Exilim EX Z55 Motherboard Replacement, LCD Screen: 步骤 5 中的图像 3,3
    • Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
  6. Casio Exilim EX Z55 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
    • Then, remove the side metal bracket by inserting the plastic opening tool under the bracket and pulling up.
  7. Casio Exilim EX Z55 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
  8. Casio Exilim EX Z55 Motherboard Replacement: 步骤 8 中的图像 1,2 Casio Exilim EX Z55 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Continue to lift the LCD screen all the way up.
    • Be careful not to rip any wires connecting the LCD screen to the top of the camera.
  9. Casio Exilim EX Z55 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,2 Casio Exilim EX Z55 Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Remove the orange ribbon cable by grabbing the white tab with your fingers and pulling gently.
    • Potential for device damage: Be careful when handling the fragile parts of the motherboard; direct contact can damage it.
  10. Casio Exilim EX Z55 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the two 1.7 mm screws from the motherboard using a Phillips #00 screwdriver.
  11. Casio Exilim EX Z55 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Using the iFixit plastic opening tool, pry the battery case clamps on the front of the camera so that the bottom will come loose.
  12. Casio Exilim EX Z55 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Detach the inner orange ribbon cable that connects the motherboard to the lens by inserting the iFixit plastic opening tool under the tab and lifting up.
  13. Casio Exilim EX Z55 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Separate and remove the motherboard from the lens.
    • It will be still be attached by wires and different orange ribbons.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2等其他人完成本指南。
Taylor
于04/18/12注册
46 声望
撰写一个指南
团队
Cal Poly, Team 9-45, Regan Spring 2012 Cal Poly, Team 9-45, Regan Spring 2012 的会员
CPSU-REGAN-S12S9G45
7 名成员
创作了14篇指南
1指南评论
I veganlover loved this guide! Although it wasn’t vegan enough
Alex Goodwin - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 15
总计 1,214
