简介
If your Casio Cassiopeia (model E-125) is having issues with its touchscreen—faulty control screen, cracked screen, or no visual—this guide will walk you through replacing it.
Before using this guide, be sure to carefully read the process of removing power/disconnecting batteries. The document will walk you through how to prevent device damage.
The device should be fully powered off before beginning to replace the touchscreen.
你所需要的
Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
即将完成!
结论
