1. Flip the device over to the back side.
    • Flip the device over to the back side.
  2. Slide the small switch on the back to "MAIN".
    • Slide the small switch on the back to "MAIN".
  3. Slide the battery cover downwards.
    • Slide the battery cover downwards.
    • Pull off the battery cover.
  4. Pull the black tab to remove the battery.
    • Pull the black tab to remove the battery.
  5. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  6. Using the Phillips #00 screwdriver, remove the two screws near the top of the device.
    • Using the Phillips #00 screwdriver, remove the two screws near the top of the device.
  7. Using the Phillips #00 screwdriver, remove the two screws located inside the battery compartment.
    • Using the Phillips #00 screwdriver, remove the two screws located inside the battery compartment.
  8. Partially separate the two halves of the case by inserting the tip of a small flat head screw driver into the space between the halves.
    • Partially separate the two halves of the case by inserting the tip of a small flat head screw driver into the space between the halves.
  9. Pry the two halves of the case apart with the small flat head screwdriver.
    • Pry the two halves of the case apart with the small flat head screwdriver.
  10. Caution: be careful not to pull out the wires connecting the two halves of the outer case. These wires are necessary for the device to be able to function.
    • Caution: be careful not to pull out the wires connecting the two halves of the outer case. These wires are necessary for the device to be able to function.
    • Lay the two halves of the outer case next to the central components as shown.
  11. Using the #00 Phillips screwdriver, remove the screws from the corners of the screen. There are 3 screws total.
    • Using the #00 Phillips screwdriver, remove the screws from the corners of the screen. There are 3 screws total.
  12. Lift the tab on the motherboard and pull out the ribbon cable. After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
    • Lift the tab on the motherboard and pull out the ribbon cable.
    • After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
结论
Ryan Fernandez
于2012年04月03日注册
47 信誉积分
创作了5篇指南
团队
Cal Poly, Team 5-4, Forte Spring 2012 Cal Poly, Team 5-4, Forte Spring 2012 的会员
CPSU-FORTE-S12S5G4
6 名成员
创作了5篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 670
