跳转到主内容
Casio Cassiopeia E-125 Motherboard Replacement
你所需要的
  1. Casio Cassiopeia E-125 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the device over to the back side.
  2. Casio Cassiopeia E-125 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Slide the small switch on the back to "MAIN".
  3. Casio Cassiopeia E-125 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Slide the battery cover downwards.
    • Pull off the battery cover.
  4. Casio Cassiopeia E-125 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Pull the black tab to remove the battery.
  5. Casio Cassiopeia E-125 Motherboard Replacement, Touch Screen: 步骤 5 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
  6. Casio Cassiopeia E-125 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the two screws located inside the battery compartment.
  7. Casio Cassiopeia E-125 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use a spudger or opening tool to separate the two halves of the case.
  8. Casio Cassiopeia E-125 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Pry the two halves of the case apart with the opening tool.
  9. Casio Cassiopeia E-125 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Potential for device damage. Do not pull apart the wires connecting the outer case.
    • Lay the two halves of the outer case next to the central components as shown.
  10. Casio Cassiopeia E-125 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Use the Philips #00 screwdriver to remove the three screws in the corners of the screen.
  11. Casio Cassiopeia E-125 Motherboard Replacement: 步骤 11 中的图像 1,2 Casio Cassiopeia E-125 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Lift the tab on the motherboard and pull out the ribbon cable.
    • After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
  12. Casio Cassiopeia E-125 Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Locate the small grey ribbon cable towards the bottom of the device. It should be located above the battery slot. Pinch both sides of the ribbon cable and pull it out.
  13. Casio Cassiopeia E-125 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Locate the multicolored wire on the motherboard near the battery compartment. Pull on the wire by the base and lift to remove.
  14. Casio Cassiopeia E-125 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Use the Phillips #00 Screwdriver to remove the two screws from the green circuit board on the back case.
  15. Casio Cassiopeia E-125 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Remove the the three screws on the motherboard that are shown using the Phillips #00 Screwdriver.
  16. Casio Cassiopeia E-125 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Caution: do not break ribbon cables from the motherboard because this may cause damage to your device.
    • Flip the motherboard towards the front cover to expose the ribbon cables underneath.
  17. Casio Cassiopeia E-125 Motherboard Replacement: 步骤 17 中的图像 1,2 Casio Cassiopeia E-125 Motherboard Replacement: 步骤 17 中的图像 2,2
    • Locate the two ribbon cables on the motherboard. Select one to remove first and then pinch either side of it and pull out to remove the ribbon cable. Do the same for the second.
结论
另外一个人完成了本指南。
Ryan Fernandez
于04/03/12注册
47 声望
创作了5篇指南
团队
Cal Poly, Team 5-4, Forte Spring 2012 Cal Poly, Team 5-4, Forte Spring 2012 的会员
CPSU-FORTE-S12S5G4
6 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 1,159
