跳转到主内容
Casio Cassiopeia E-125 Key Pad Replacement
你所需要的
  1. Casio Cassiopeia E-125 Key Pad Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the device over to the back side.
  2. Casio Cassiopeia E-125 Key Pad Replacement: 步骤 2 中的图像 1,1
    • Slide the small switch on the back to "MAIN".
  3. Casio Cassiopeia E-125 Key Pad Replacement: 步骤 3 中的图像 1,1
    • Slide the battery cover downwards.
    • Pull off the battery cover.
  4. Casio Cassiopeia E-125 Key Pad Replacement: 步骤 4 中的图像 1,1
    • Pull the black tab to remove the battery.
  5. Casio Cassiopeia E-125 Key Pad Replacement, Touch Screen: 步骤 5 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
  6. Casio Cassiopeia E-125 Key Pad Replacement: 步骤 6 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the two screws located inside the battery compartment.
  7. Casio Cassiopeia E-125 Key Pad Replacement: 步骤 7 中的图像 1,1
    • Use a spudger or opening tool to separate the two halves of the case.
  8. Casio Cassiopeia E-125 Key Pad Replacement: 步骤 8 中的图像 1,1
    • Pry the two halves of the case apart with the opening tool.
  9. Casio Cassiopeia E-125 Key Pad Replacement: 步骤 9 中的图像 1,1
    • Potential for device damage. Do not pull apart the wires connecting the outer case.
    • Lay the two halves of the outer case next to the central components as shown.
  10. Casio Cassiopeia E-125 Key Pad Replacement: 步骤 10 中的图像 1,1
    • Use the Philips #00 screwdriver to remove the three screws in the corners of the screen.
  11. Casio Cassiopeia E-125 Key Pad Replacement: 步骤 11 中的图像 1,2 Casio Cassiopeia E-125 Key Pad Replacement: 步骤 11 中的图像 2,2
    • Lift the tab on the motherboard and pull out the ribbon cable.
    • After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
  12. Casio Cassiopeia E-125 Key Pad Replacement, Key Pad: 步骤 12 中的图像 1,1
    • Use the Phillips #00 screwdriver and remove the five screws from the daughterboard.
  13. Casio Cassiopeia E-125 Key Pad Replacement: 步骤 13 中的图像 1,1
    • Pull the ribbon cable out of its port on the back of the keypad.
  14. Casio Cassiopeia E-125 Key Pad Replacement: 步骤 14 中的图像 1,1
    • Now, lift the keypad off the front case.
结论
Ryan Fernandez
于04/03/12注册
47 声望
创作了5篇指南
团队
Cal Poly, Team 5-4, Forte Spring 2012 Cal Poly, Team 5-4, Forte Spring 2012 的会员
CPSU-FORTE-S12S5G4
6 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 616
