跳转到主内容
Casio CZ-1000 Power Switch Replacement
你所需要的
  1. Casio CZ-1000 Power Switch Replacement, Backplate: 步骤 1 中的图像 1,2 Casio CZ-1000 Power Switch Replacement, Backplate: 步骤 1 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
  2. Casio CZ-1000 Power Switch Replacement: 步骤 2 中的图像 1,3 Casio CZ-1000 Power Switch Replacement: 步骤 2 中的图像 2,3 Casio CZ-1000 Power Switch Replacement: 步骤 2 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
  3. Casio CZ-1000 Power Switch Replacement: 步骤 3 中的图像 1,3 Casio CZ-1000 Power Switch Replacement: 步骤 3 中的图像 2,3 Casio CZ-1000 Power Switch Replacement: 步骤 3 中的图像 3,3
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
  4. Casio CZ-1000 Power Switch Replacement, Power Switch: 步骤 4 中的图像 1,1
    • Remove the two 5.5 mm screws holding the power switch to the case using a Phillips #1 screwdriver.
  5. Casio CZ-1000 Power Switch Replacement: 步骤 5 中的图像 1,3 Casio CZ-1000 Power Switch Replacement: 步骤 5 中的图像 2,3 Casio CZ-1000 Power Switch Replacement: 步骤 5 中的图像 3,3
    • Heat the soldering iron and use a desoldering braid or pump to remove the solder from the pins of the old switch.
    • Once the solder is removed, gently pull the old switch out of its place.
    • If the replacement switch doesn’t have pre-attached leads, you’ll need to solder wires to it. If it has leads, align them with the matching holes on the PCB where the old switch was connected.
    • Position the new switch in place, ensuring the leads align correctly with the pads on the PCB. Solder the leads securely, using just enough solder to create a strong connection without any excess that might cause shorts.
结论
Luke Farmer
于11/05/24注册
235 声望
撰写一个指南
团队
Cuesta, Team 60-3, Krynen Fall 2024 Cuesta, Team 60-3, Krynen Fall 2024 的会员
CUESTA-KRYNEN-F24S60G3
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 133
