跳转到主内容
Casio CTK-501 Speaker Replacement
你所需要的
  1. Casio CTK-501 Speaker Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Casio CTK-501 Speaker Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Speaker Replacement: 步骤 3 中的图像 1,2 Casio CTK-501 Speaker Replacement: 步骤 3 中的图像 2,2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Speaker Replacement, Speaker: 步骤 4 中的图像 1,1
    • Plug in the soldering iron and place somewhere safe to avoid burning yourself or causing a fire.
    • Completely unscrew and remove all four screws in the corners of the speaker.
  5. Casio CTK-501 Speaker Replacement: 步骤 5 中的图像 1,1
    • Pull the speaker out of the keyboard and set on a flat surface to solder safely.
  6. Casio CTK-501 Speaker Replacement: 步骤 6 中的图像 1,1
    • Be careful when removing the wires and avoid dripping solder on yourself or the keyboard.
    • Touch soldering iron to solder over the end of the wires, and when the solder melts, pull the wires away from the speaker.
    • Remove the speaker and replace with a new one.
  7. Casio CTK-501 Speaker Replacement: 步骤 7 中的图像 1,1
    • Strip the wires if you need more clean metal to solder to the speaker.
    • Use the soldering iron to melt the solder over the wire to connect them to the speaker.
  8. Casio CTK-501 Speaker Replacement: 步骤 8 中的图像 1,1
    • Completely screw in the screws back into the original positions on the corner of the speaker.
结论
另外一个人完成了本指南。
Jimmy Winne
于10/04/12注册
578 声望
创作了6篇指南
团队
Cal Poly, Team 9-16, Amido Fall 2012 Cal Poly, Team 9-16, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G16
4 名成员
创作了6篇指南
一条评论
I have a Casio ctk 691 Keyboard and it’s not Turning up is working is coming on but my volume slider is not working
Jacameron Bussey - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 6,431
