跳转到主内容
Casio CTK-501 Keys Replacement
你所需要的
  1. Casio CTK-501 Keys Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Casio CTK-501 Keys Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Keys Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Keys Replacement: 步骤 3 中的图像 1,2 Casio CTK-501 Keys Replacement: 步骤 3 中的图像 2,2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Keys Replacement, Keys: 步骤 4 中的图像 1,1
    • Completely unscrew and remove the screws holding the broken string of keys in place.
  5. Casio CTK-501 Keys Replacement: 步骤 5 中的图像 1,1
    • Pull up the top layer of white keys to remove them from the keyboard.
  6. Casio CTK-501 Keys Replacement: 步骤 6 中的图像 1,1
    • Pull up on the last layer of white keys to remove them.
  7. Casio CTK-501 Keys Replacement: 步骤 7 中的图像 1,1
    • Push the black keys toward the front of the keyboard and rotate them until they fall out of the keyboard.
结论
7等其他人完成本指南。
Jimmy Winne
于10/04/12注册
578 声望
创作了6篇指南
团队
Cal Poly, Team 9-16, Amido Fall 2012 Cal Poly, Team 9-16, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G16
4 名成员
创作了6篇指南
4指南评论
my ctk710 keybord circuit failure.... how to get new circuit in online plg help me
michael Akhil - 回复
Please do you know where to get Casio CTK700/720 (or compatible) complete Keys set replacement?
Thanks in advance!
Fred from Brasil
Luis Frederico - 回复
pliskers@optonline.net
Will replacing keys cure a rattle/chatter that I hear from my middle C and D keys when they are played?
pliskers - 回复
I want to repair my Roland Ex 20 keyboard keys because my middle position two keys are muted.
Jit Ghosh - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 30
总计 25,874
