跳转到主内容
Casio CTK-501 Buttons Replacement
你所需要的
  1. Casio CTK-501 Buttons Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Casio CTK-501 Buttons Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Buttons Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Buttons Replacement: 步骤 3 中的图像 1,2 Casio CTK-501 Buttons Replacement: 步骤 3 中的图像 2,2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Buttons Replacement, Buttons: 步骤 4 中的图像 1,1
    • Remove the nine screws from the brown circuit board that has an attached ribbon, with a #0 Phillips.
  5. Casio CTK-501 Buttons Replacement: 步骤 5 中的图像 1,1
    • Remove the circuit board, by pulling upwards.
  6. Casio CTK-501 Buttons Replacement: 步骤 6 中的图像 1,1
    • Remove the buttons.
  7. Casio CTK-501 Buttons Replacement: 步骤 7 中的图像 1,1
    • Place the new buttons into the slot, and push downward in the slot.
结论
2等其他人完成本指南。
Jimmy Winne
于10/04/12注册
578 声望
创作了6篇指南
团队
Cal Poly, Team 9-16, Amido Fall 2012 Cal Poly, Team 9-16, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G16
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 2,276
