跳转到主内容
Casio A158WA-1 Watch Circuit Board Replacement
你所需要的
  1. Casio A158WA-1 Watch Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 1,1
    • Remove the four screws from the back of the watch using a Phillips #00 screwdriver.
  2. Casio A158WA-1 Watch Circuit Board Replacement: 步骤 2 中的图像 1,2 Casio A158WA-1 Watch Circuit Board Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the back cover and the black rubber band with tweezers.
  3. Casio A158WA-1 Watch Circuit Board Replacement: 步骤 3 中的图像 1,2 Casio A158WA-1 Watch Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Use a pair of tweezers to pull the small metal tab and remove the interior of the watch.
  4. Casio A158WA-1 Watch Circuit Board Replacement: 步骤 4 中的图像 1,2 Casio A158WA-1 Watch Circuit Board Replacement: 步骤 4 中的图像 2,2
    • Use a pair of tweezers to lift the metal clasps at each corner and remove the battery holder.
  5. Casio A158WA-1 Watch Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Separate the LCD from the circuit board.
  6. Casio A158WA-1 Watch Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Remember the position of the battery for reassembly.
    • Detach the battery from the circuit board.
  7. Casio A158WA-1 Watch Circuit Board Replacement: 步骤 7 中的图像 1,1
    • Attach the battery to the new circuit board.
  8. Casio A158WA-1 Watch Circuit Board Replacement: 步骤 8 中的图像 1,3 Casio A158WA-1 Watch Circuit Board Replacement: 步骤 8 中的图像 2,3 Casio A158WA-1 Watch Circuit Board Replacement: 步骤 8 中的图像 3,3
    • Place the new circuit board behind the LCD.
  9. Casio A158WA-1 Watch Circuit Board Replacement: 步骤 9 中的图像 1,2 Casio A158WA-1 Watch Circuit Board Replacement: 步骤 9 中的图像 2,2
    • Reattach the battery holder and push down on the clasps at each corner.
  10. Casio A158WA-1 Watch Circuit Board Replacement: 步骤 10 中的图像 1,3 Casio A158WA-1 Watch Circuit Board Replacement: 步骤 10 中的图像 2,3 Casio A158WA-1 Watch Circuit Board Replacement: 步骤 10 中的图像 3,3
    • Place the interior of the watch inside of the shell.
    • Put the rubber band and the lid back in their original position.
终点
1指南评论
Hi! I believe I have this problem with my Casio royal. Where do you buy the replacements?
Bernardo Rabitti - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 66
总计 2,159
