跳转到主内容
Casio A158W-1 Battery Replacement
你所需要的
  1. Casio A158W-1 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Casio A158W-1 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Casio A158W-1 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Using the Phillips #00 screwdriver, remove the four screws from the back panel of the watch.
  2. Casio A158W-1 Battery Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • With your fingers, or tweezers if available, remove the rubber gasket surrounding the base of the watch.
  3. Casio A158W-1 Battery Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the centerpiece of the watch from the casing.
  4. Casio A158W-1 Battery Replacement: 步骤 4 中的图像 1,1
    • Using the Flathead screwdriver, push the four tabs located around the centerpiece inwards to open it up.
  5. Casio A158W-1 Battery Replacement: 步骤 5 中的图像 1,2 Casio A158W-1 Battery Replacement: 步骤 5 中的图像 2,2
    • Open up the centerpiece to reveal the battery.
    • Carefully remove the dead battery.
  6. Casio A158W-1 Battery Replacement: 步骤 6 中的图像 1,1
    • Insert the new Cr2016 3V Lithium battery into the centerpiece.
    • Reattach the back of the centerpiece together.
  7. Casio A158W-1 Battery Replacement: 步骤 7 中的图像 1,2 Casio A158W-1 Battery Replacement: 步骤 7 中的图像 2,2
    • Insert the centerpiece back into the casing of the watch with the "front" facing down.
    • Position the rubber gasket back into place.
  8. Casio A158W-1 Battery Replacement: 步骤 8 中的图像 1,2 Casio A158W-1 Battery Replacement: 步骤 8 中的图像 2,2
    • After putting the back panel of the watch into place, use the Phillips #00 screwdriver to screw four screws into place.
  9. Casio A158W-1 Battery Replacement: 步骤 9 中的图像 1,1
    • Finally, reset the Casio watch to the correct time.
    • Make sure all buttons are operational.
结论
3等其他人完成本指南。
Libaan Major
于09/10/21注册
241 声望
撰写一个指南
团队
York University, Team 1-12, O'Regan Fall 2021 York University, Team 1-12, O'Regan Fall 2021 的会员
YORK-O'REGAN-F21S1G12
1 名成员
创作了3篇指南
一条评论
Thanks for the guide! I successfully managed to replace my battery. A few things I noticed during my own attempt:
1. The centerpiece cover only fits in one way when replacing it over the battery, because one side of the watch has two buttons and the other side only has one.
2. Immediately after replacing the battery and replacing the centerpiece cover, only some segments of the display were working and the watch was non-functioning. After a little googling I discovered that a CMOS clear might be required, and I followed https://rajgopalmenon.wordpress.com/2020... in order to do this. Within 5 minutes of doing the CMOS clear my watch started working again.
Sanuja - 回复
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 153
过去 30 天: 639
总计 16,020
