本指南有最近更改,您可查看未经巡查的最新版本。
简介
Using a PH100 screwdriver, a set of wire cutters, and a soldering tool, the on/off switch can be replaced in the Casdon Dyson Ball.
你所需要的
Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
一条评论
Great instructions but where can you purchase the on of switch and what is the part number?
debbyh1024 - 回复
