简介
Using a PH100 screwdriver, a set of wire cutters, and a soldering tool, the on/off switch can be replaced in the Casdon Dyson Ball.
你所需要的
Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
Cut the two wires connected to the on/off switch using a set of wire cutters.
What is underneath the little board that’s circled and in between that and the black plastic on off switch as my sons has broke I put it back together as so but it doesn’t work but if I put the screwdriver on the metal solder point of the wire it comes on so I’m guessing there should be a metal bit that slides across underneath the bit circled in the picture to make the connection on or off.
Remove the on/off switch by pulling it away from the vacuum with your fingers.
Replace the faulty on/off switch with the new on/off switch.
一条评论
Great instructions but where can you purchase the on of switch and what is the part number?
debbyh1024 - 回复
