介绍
Using a PH100 screwdriver, a set of wire cutters, and a soldering tool, the on/off switch can be replaced in the Casdon Dyson Ball.
  1. Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Remove batteries from the vacuum by pulling them out and away from the vacuum.
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
    • Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
  4. Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
    Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
  5. Remove the cover to the on/off switch by pulling up on the cover from the front of the vacuum.
    • Remove the cover to the on/off switch by pulling up on the cover from the front of the vacuum.
  6. Cut the two wires connected to the on/off switch using a set of wire cutters.
    • Cut the two wires connected to the on/off switch using a set of wire cutters.
    What is underneath the little board that’s circled and in between that and the black plastic on off switch as my sons has broke I put it back together as so but it doesn’t work but if I put the screwdriver on the metal solder point of the wire it comes on so I’m guessing there should be a metal bit that slides across underneath the bit circled in the picture to make the connection on or off.
    benrandle - 回复
  7. Remove the two 9.2mm (0.32 in) screws which hold the on/off switch to the vacuum using the PH00 screwdriver.
    • Remove the two 9.2mm (0.32 in) screws which hold the on/off switch to the vacuum using the PH00 screwdriver.
  8. Remove the on/off switch by pulling it away from the vacuum with your fingers.
    • Remove the on/off switch by pulling it away from the vacuum with your fingers.
    • Replace the faulty on/off switch with the new on/off switch.
    • Solder the new on/off switch's wires to the vacuum's wires using a soldering station.
结论
Seldon Price
于2017年11月07日注册
531 Reputation
创作了5篇指南
IUPUI, Team S3-G5, Harley Fall 2017 IUPUI, Team S3-G5, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S3G5
3 名成员
创作了5篇指南
One Comment
Great instructions but where can you purchase the on of switch and what is the part number?
debbyh1024 - 回复
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 383
