跳转到主内容
Casdon Dyson Ball On/Off Switch Replacement
你所需要的
  1. Casdon Dyson Ball On/Off Switch Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball On/Off Switch Replacement: 步骤 2 中的图像 1,1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball On/Off Switch Replacement, On/Off Switch: 步骤 3 中的图像 1,1
    • Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
  4. Casdon Dyson Ball On/Off Switch Replacement: 步骤 4 中的图像 1,1
    • Remove the cover to the on/off switch by pulling up on the cover from the front of the vacuum.
  5. Casdon Dyson Ball On/Off Switch Replacement: 步骤 5 中的图像 1,1
    • Cut the two wires connected to the on/off switch using a set of wire cutters.
  6. Casdon Dyson Ball On/Off Switch Replacement: 步骤 6 中的图像 1,1
    • Remove the two 9.2mm (0.32 in) screws which hold the on/off switch to the vacuum using the PH00 screwdriver.
  7. Casdon Dyson Ball On/Off Switch Replacement: 步骤 7 中的图像 1,1
    • Remove the on/off switch by pulling it away from the vacuum with your fingers.
    • Replace the faulty on/off switch with the new on/off switch.
    • Solder the new on/off switch's wires to the vacuum's wires using a soldering station.
结论
Seldon Price
于11/07/17注册
612 声望
创作了5篇指南
团队
IUPUI, Team S3-G5, Harley Fall 2017 IUPUI, Team S3-G5, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S3G5
3 名成员
创作了10篇指南
一条评论
Great instructions but where can you purchase the on of switch and what is the part number?
debbyh1024 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 17
总计 2,122
