跳转到主内容
Casdon Dyson Ball Disassembly
你所需要的
  1. Casdon Dyson Ball Disassembly, Battery: 步骤 1 中的图像 1,1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Disassembly: 步骤 2 中的图像 1,1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball Disassembly, Casdon Dyson Ball Disassembly: 步骤 3 中的图像 1,1
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
  4. Casdon Dyson Ball Disassembly: 步骤 4 中的图像 1,1
    • Remove the front side covers by pulling them away from the vacuum.
  5. Casdon Dyson Ball Disassembly: 步骤 5 中的图像 1,1
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Casdon Dyson Ball Disassembly: 步骤 6 中的图像 1,1
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
  7. Casdon Dyson Ball Disassembly: 步骤 7 中的图像 1,1
    • Remove beads from the container.
结论
2等其他人完成本指南。
Seldon Price
于11/07/17注册
612 声望
创作了5篇指南
团队
IUPUI, Team S3-G5, Harley Fall 2017 IUPUI, Team S3-G5, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S3G5
3 名成员
创作了10篇指南
2条评论
How do I get the handle out once assembled?
Carie McClendon - 回复
The fan to make the beads jump around no longer works….is there. Separate battery for that?
Kathy - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 110
总计 12,438
