跳转到主内容
Casdon Dyson Ball Ball Motor Replacement
你所需要的
  1. Casdon Dyson Ball Ball Motor Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Ball Motor Replacement: 步骤 2 中的图像 1,1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball Ball Motor Replacement, Casdon Dyson Ball Disassembly: 步骤 3 中的图像 1,1
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
  4. Casdon Dyson Ball Ball Motor Replacement: 步骤 4 中的图像 1,1
    • Remove the front side covers by pulling them away from the vacuum.
  5. Casdon Dyson Ball Ball Motor Replacement: 步骤 5 中的图像 1,1
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Casdon Dyson Ball Ball Motor Replacement: 步骤 6 中的图像 1,1
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
  7. Casdon Dyson Ball Ball Motor Replacement: 步骤 7 中的图像 1,1
    • Remove beads from the container.
  8. Casdon Dyson Ball Ball Motor Replacement, Ball Motor: 步骤 8 中的图像 1,1
    • Remove the three 11.5mm (0.45 in) screws at bottom of bead cylinder container using the PH00 screwdriver.
  9. Casdon Dyson Ball Ball Motor Replacement: 步骤 9 中的图像 1,1
    • Remove the bead cylinder and motor mount from the vacuum ball.
  10. Casdon Dyson Ball Ball Motor Replacement: 步骤 10 中的图像 1,1
    • Separate the motor mount from the bead cylinder by pulling the motor mount away from the bead cylinder.
  11. Casdon Dyson Ball Ball Motor Replacement: 步骤 11 中的图像 1,1
    • Separate the fan from the motor shaft by pulling the fan away from the motor.
  12. Casdon Dyson Ball Ball Motor Replacement: 步骤 12 中的图像 1,1
    • Cut the wires to the faulty motor using wire cutters.
  13. Casdon Dyson Ball Ball Motor Replacement: 步骤 13 中的图像 1,1
    • Remove and replace the faulty ball motor with a new one.
    • Solder the new ball motor's wires to the vacuum's wires which were previously cut.
结论
另外一个人完成了本指南。
Seldon Price
于11/07/17注册
612 声望
创作了5篇指南
团队
IUPUI, Team S3-G5, Harley Fall 2017 IUPUI, Team S3-G5, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S3G5
3 名成员
创作了10篇指南
一条评论
Thank you for the guide, it helped me successfully repair the top motor that stirs the colored pellets. My son will be so happy to see it working again!
Garrett - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 665
