跳转到主内容
Carrier 58MSA060-08 Furnace Filter Replacement
你所需要的
  1. Carrier 58MSA060-08 Furnace Filter Replacement, Furnace Filter: 步骤 1 中的图像 1,2 Carrier 58MSA060-08 Furnace Filter Replacement, Furnace Filter: 步骤 1 中的图像 2,2
    • Locate the furnace disconnect switch.
    • Flip the switch from the "ON" position to the "OFF" position.
  2. Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 2 中的图像 1,1
    • The filter is located in between the return duct and the main furnace unit.
  3. Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 3 中的图像 1,3 Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 3 中的图像 2,3 Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 3 中的图像 3,3
    • Pull the filter cover off of the duct to remove it and expose the filter.
  4. Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 4 中的图像 1,2 Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 4 中的图像 2,2
    • Examine your furnace to determine the air flow direction.
    • The Return Duct
    • The Furnace Unit
    • The air will always flow from the return duct towards the furnace unit.
    • Your old filter may also have an arrow indicator on the side.
    • The arrow's direction will indicate the air flow direction.
  5. Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 5 中的图像 1,3 Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 5 中的图像 2,3 Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 5 中的图像 3,3
    • Remove the old filter by pulling it out of the duct.
  6. Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 6 中的图像 1,3 Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 6 中的图像 2,3 Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 6 中的图像 3,3
    • Insert the new filter.
    • Pay attention to which direction the new filter should face before inserting it; make it is correct.
  7. Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 7 中的图像 1,2 Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 7 中的图像 2,2
    • Reattach the filter cover.
    • Ensure that the filter cover is securely in place.
  8. Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 8 中的图像 1,2 Carrier 58MSA060-08 Furnace Filter Replacement: 步骤 8 中的图像 2,2
    • Turn on the furnace.
    • Flip the switch from the "OFF" position to the "ON" position.
结论
Once you have completed these steps, your furnace filter replacement will be complete.
2等其他人完成本指南。
Alexander Ye
于01/19/22注册
184 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 36
过去 30 天: 122
总计 5,805
