跳转到主内容
Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement
你所需要的
  1. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement, Axle Replacement Guide: 步骤 1 中的图像 1,1
    • Flip the car with the bottom side facing up.
    • Using a Philips screwdriver, remove the middle screw on the front axle while holding it the axle in place.
    • Carefully place the screw in a magnetic pad (or somewhere you won’t loose)
  2. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: 步骤 2 中的图像 1,1
    • Place the new axle where on the curved side is pointed towards center.
    • Screw it into place but make sure it isn't too tight. The axle needs to able to move a bit.
  3. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: 步骤 3 中的图像 1,1
    • Repeat the same steps for the back axle of the car but without concern of the curved part.
  4. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: 步骤 4 中的图像 1,1
    • Place the new wheel into the car and attach the new screw
结论
Kimberly Santos
于09/25/17注册
331 声望
创作了3篇指南
团队
USF Tampa, Team S3-G5, Cannon Fall 2017 USF Tampa, Team S3-G5, Cannon Fall 2017 的会员
USFT-CANNON-F17S3G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 803
