跳转到主内容
Carrera Mario Copter Rotor Blade Replacement
你所需要的
  1. Carrera Mario Copter Rotor Blade  Replacement, Rotor Blade: 步骤 1 中的图像 1,1
    • Using the JIS #00 screwdriver, hold the rotor blade still and unscrew the 4.762mm screw in the center of the blade.
  2. Carrera Mario Copter Rotor Blade  Replacement: 步骤 2 中的图像 1,1
    • Lift the screw out and set it aside.
    • Lift the rotor blade out.
    • Be sure to place the rotor blades properly for stable flight. With the quadrocopter facing you, the front rotor blades should be red with blade A on the right and B on the left. The rear rotor blades should be blue with blade B on the right and A on the left.
结论
Marissa Espino
于10/23/17注册
101 声望
撰写一个指南
团队
UW Tacoma, Team S1-G6, Rose Fall 2017 UW Tacoma, Team S1-G6, Rose Fall 2017 的会员
UWT-ROSE-F17S1G6
4 名成员
创作了10篇指南
一条评论
Hi. How i can buy the rotor blade
Ainul Abd Rahim - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,441
