跳转到主内容
Carrera Mario Copter Motherboard Replacement
你所需要的
  1. Carrera Mario Copter Motherboard  Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the quadrocopter over so that the underside of the device is facing up.
    • Unplug the battery cable from the socket on the quadrocopter.
  2. Carrera Mario Copter Motherboard  Replacement: 步骤 2 中的图像 1,1
    • Push the battery upward with your thumbs to loosen it from the tight slot until your thumbs can not reach the bottom of the battery anymore.
  3. Carrera Mario Copter Motherboard  Replacement: 步骤 3 中的图像 1,1
    • Pull the battery away from the slot to remove it.
  4. Carrera Mario Copter Motherboard  Replacement, Motherboard: 步骤 4 中的图像 1,2 Carrera Mario Copter Motherboard  Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Using the Phillips # PH00 screwdriver unscrew the four 7.1mm screws in the black circle base.
    • Remove the entire black circle base and flip it over so you can see the motherboard.
  5. Carrera Mario Copter Motherboard  Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers remove the four white heads wires from the motherboard.
    • Be careful not to cut the wires plugged to the little white heads. Grab onto the plastic connectors if possible.
  6. Carrera Mario Copter Motherboard  Replacement: 步骤 6 中的图像 1,2 Carrera Mario Copter Motherboard  Replacement: 步骤 6 中的图像 2,2
    • Using the tweezers remove the golden head screws that hold down the motherboard.
    • Hold strong the motherboard and pull up strong the head screws.
    • Be careful not to hurt yourself. You will need to try several times to remove those.
结论
另外一个人完成了本指南。
Stephany Martinez
于10/23/17注册
122 声望
撰写一个指南
团队
UW Tacoma, Team S1-G6, Rose Fall 2017 UW Tacoma, Team S1-G6, Rose Fall 2017 的会员
UWT-ROSE-F17S1G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 330
