你所需要的
Some people simply cut the old battery wires and heat shrink them to new battery wires to avoid having to re-solder the small solder points on the PCB.
If you want to ensure your unit stays waterproof, you can add a thin line of silicone seal around case prior to reassembly
2指南评论
Can you recommend a battery to purchase for the Packtalk BOLD? Thanks!
I can't recommend a particular one, when my Smartpack battery died I cannibalized an OEM battery from a broken Packtalk unit.
Here are a couple batteries on offer from Ebay and Amazon that claim they fit the Packtalk and have some good reviews (do your own research):
FJrider -
