简介
The Turbine is integral to the Ventilator's function. A possible cause of failure during the delivered volume test is the turbine assembly itself. In this case the Turbine assembly must be removed, and either replaced with P/N 16349 or sent to manufacturer for Re-Characterization. This guide will walk through the necessary steps to remove the turbine assembly.
你所需要的
步骤 1 Cardinal Health Vela Ventilator Power Cable Removal
注意:步骤 1-2 源自标记为进行中的 指南。
Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
Remove the four Phillips #0 screws on the back side of the ventilator.
步骤 6 Cardinal Health Vela Ventilator Battery Tray Removal
注意:步骤 6-8 源自标记为进行中的 指南。
Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
步骤 13 Blender Assembly P/N 16358A
注意:步骤 13-21 源自标记为进行中的 指南。
If the rear panel is installed, remove the high and low pressure oxygen fittings from the rear panel using your 3/4" wrench. NOTE: the high pressure fitting is located above the low pressure fitting
Disconnect the main wire harness connector at P2 on the Turbine Driver PCBA
另外一个人完成了本指南。
