跳转到主内容
Cardinal Health Vela Ventilator Left Panel Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. 注意:步骤 1-2 源自标记为进行中的 指南
    Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Power Cable Removal: 步骤 1 中的图像 1,1
    • Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
    • Remove the plug guard and unplug the ventilator.
  2. Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Top Cover Disassembly: 步骤 3 中的图像 1,1
    • Remove the four Phillips #0 screws on the back side of the ventilator.
  3. Cardinal Health Vela Ventilator Left Panel Replacement: 步骤 4 中的图像 1,1
    • Remove all six small side panel screws along the bottom of each side of the top cover with the same screwdriver.
    • Slide the top cover towards the back side of the ventilator to remove it.
  4. 注意:步骤 6-8 源自标记为进行中的 指南
    Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Battery Tray Removal: 步骤 6 中的图像 1,1
    • Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
    • Lift the battery tray out of the ventilator.
    • Caution: The wires connecting the batteries to the ventilator will still be connected so lift the battery tray carefully.
  5. Cardinal Health Vela Ventilator Left Panel Replacement: 步骤 8 中的图像 1,1
    • Disconnect the batteries from the ventilator by pulling apart the Battery Connector.
    • Remove the two Phillips countersink at the rear of the panel.
    • Remove the Phillips countersink in the upper front of the panel.
    • The panel is now free and can be lifted from the device.
    • To install the left panel follow these steps in reverse order.
结论
Tanner Hillman
于04/10/20注册
370 声望
创作了3篇指南
团队
Cal Poly, Team S7-G22, Paton Spring 2020 Cal Poly, Team S7-G22, Paton Spring 2020 的会员
CPSU-PATON-S20S7G22
1 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 105
