跳转到主内容
Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM
你所需要的
  1. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Necessary tools: 步骤 1 中的图像 1,2 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Necessary tools: 步骤 1 中的图像 2,2
    • A flathead screwdriver
    • A Phillips head screwdriver
    • A T25 torx wrench
    • A Carburetor Adjusting Hex Screwdriver
  2. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Remove the air filter: 步骤 2 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Remove the air filter: 步骤 2 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Remove the air filter: 步骤 2 中的图像 3,3
    • Unclip the air filter cover.
    • Extract the air filter.
    • Filter and carburetor case fixing screws
  3. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Dismantling the carburetor: 步骤 3 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Dismantling the carburetor: 步骤 3 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Dismantling the carburetor: 步骤 3 中的图像 3,3
    • In an anticlockwise movement, unscrew the two fixing screws using a T25 torx key.
    • Remove the two screws and then the filter case.
    • Remove the carburetor.
  4. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburettor disassembly: 步骤 4 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburettor disassembly: 步骤 4 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburettor disassembly: 步骤 4 中的图像 3,3
    • Unhook the accelerator cable. Make sure to remember the location.
    • Extract the transparent fuel return hose.
    • Extract the black fuel inlet hose.
  5. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor Disassembly 1/5: 步骤 5 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor Disassembly 1/5: 步骤 5 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor Disassembly 1/5: 步骤 5 中的图像 3,3
    • Unscrew the two priming pump attachment screws by turning them counterclockwise.
    • Remove the pump.
    • Peel off the pump membrane.
  6. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor Disassembly 2/5: 步骤 6 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor Disassembly 2/5: 步骤 6 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor Disassembly 2/5: 步骤 6 中的图像 3,3
    • Once the pump is disassembled, turn the carburetor 180° to access the four mounting screws.
    • Use a Phillips screwdriver to remove the four membrane cover screws.
  7. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 3/5: 步骤 7 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 3/5: 步骤 7 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 3/5: 步骤 7 中的图像 3,3
    • Remove the membrane cover.
    • Remove the needle lever membrane with the membrane seal.
    • Note: The membrane lever will act on the needle lever.
  8. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 4/5: 步骤 8 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 4/5: 步骤 8 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 4/5: 步骤 8 中的图像 3,3
    • Unscrew the screw that holds the needle lever shaft.
    • CAUTION: Be sure to hold the lever with your thumb to prevent the spring from popping out.
    • Remove the lever, the spring, and the needle.
  9. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 5/5: 步骤 9 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 5/5: 步骤 9 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 5/5: 步骤 9 中的图像 3,3
    • Set screw
    • Unscrew the two adjustment screws counterclockwise using the specific adjustment screwdriver.
    • Extract the two screws.
  10. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Cleaning the carburettor in the tank: 步骤 10 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Cleaning the carburettor in the tank: 步骤 10 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Cleaning the carburettor in the tank: 步骤 10 中的图像 3,3
    • Immerse the carburetor in the ultrasonic bath for 15 to 20 minutes at a temperature between 25 and 35°.
    • Remove the carburetor from the ultrasonic bath.
    • Rinse the carburetor with water, dry it by blowing it out with compressed air.
  11. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 11 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 11 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 11 中的图像 3,3
    • Reinstall the spring and needle.
    • Use a flat screwdriver to hold the lever in place.
    • Tighten the screw that holds the axis of the lever using a Phillips screwdriver.
  12. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 12 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 12 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 12 中的图像 3,3
    • Reinstall the needle lever membrane and the membrane gasket
    • Reinstall the membrane cover.
    • Tighten the four cover fixing screws using a Phillips screwdriver in a clockwise direction.
  13. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 13 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 13 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 13 中的图像 3,3
    • Reinsert the two adjustment screws.
    • Screw them in as far as they will go without forcing them clockwise with the adjustment screwdriver.
    • Pre-adjust the carburettor by unscrewing the two screws one and a half turns counter-clockwise
  14. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 14 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 14 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 14 中的图像 3,3
    • Take the pump cover.
    • Reposition the pump membrane and its seal.
    • Replace the pump cover and tighten the two fixing screws clockwise using a Phillips screwdriver.
  15. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 15 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 15 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 15 中的图像 3,3
    • Reinstall the black fuel inlet hose.
    • Reinstall the transparent fuel return hose.
    • Reattach the throttle cable.
  16. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 16 中的图像 1,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 16 中的图像 2,3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: 步骤 16 中的图像 3,3
    • Insert the two fixing screws in the air filter housing and then in the carburetor body.
    • ATTENTION: Make sure that the fixing screws align with the holes of the gasket.
    • Tighten the fixing screws clockwise using the T25 Torx key.
  17. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Refitting the air filter: 步骤 17 中的图像 1,2 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Refitting the air filter: 步骤 17 中的图像 2,2
    • Refit the air filter.
    • Reclips the filter cover.
终点
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 36
过去 30 天: 131
总计 3,942
