简介
Disassemble the carburetor on a Briggs and Stratton 5.5hp engine
配件
无需配件。
  1. Use a 5/16 socket or flat head screwdriver to remove the first bolt. Pull the cover off and remove the air filter. Remove the 3 bolts using a 5/16 socket. In addition, pull the breather hose off the assembly at the bottom left. Now pull the cover off. Remove the 3 bolts using a 5/16 socket. In addition, pull the breather hose off the assembly at the bottom left. Now pull the cover off.
    • Use a 5/16 socket or flat head screwdriver to remove the first bolt. Pull the cover off and remove the air filter.
    • Remove the 3 bolts using a 5/16 socket. In addition, pull the breather hose off the assembly at the bottom left. Now pull the cover off.
  2. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Remove the two bolts holding the carburetor to the engine with a 3/8 socket or wrench. Remove the spring boxed in red from the hole. Pull to left of carburetor, towards the link the other end of the spring is around. The link will be connected to the carburetor. Pull the carburetor off in an "S" motion and remove it.
    • Remove the two bolts holding the carburetor to the engine with a 3/8 socket or wrench.
    • Remove the spring boxed in red from the hole. Pull to left of carburetor, towards the link the other end of the spring is around.
    • The link will be connected to the carburetor. Pull the carburetor off in an "S" motion and remove it.
结论
Jacob Micallef
于2017年03月06日注册
782 信誉积分
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 12
总计 111
