跳转到主内容
加入维修社区 - 创建账户
Carburetor Adjustment
你所需要的
  1. Carburetor Adjustment, Install the inductive pickup lead: 步骤 1 中的图像 1,2 Carburetor Adjustment, Install the inductive pickup lead: 步骤 1 中的图像 2,2
    • Feed the inductive pickup lead wire through one of the two holes in the lower-left corner of the tachometer.
    • Bend the wire around and feed it through the second hole, then pull it tight.
  2. Carburetor Adjustment, Attach the tachometer to the spark plug wire: 步骤 2 中的图像 1,2 Carburetor Adjustment, Attach the tachometer to the spark plug wire: 步骤 2 中的图像 2,2
    • Clamp the inductive pickup lead alligator clip onto the spark plug wire.
    • Make sure the inductive pickup lead wire is not touching anything except the tachometer.
  3. Carburetor Adjustment, Start the motor: 步骤 3 中的图像 1,2 Carburetor Adjustment, Start the motor: 步骤 3 中的图像 2,2
    • Wear ear protection for the remainder of the procedure.
    • Start the motor and let it run for two minutes to ensure it reaches operating temperature.
  4. Carburetor Adjustment, Open the choke: 步骤 4 中的图像 1,3 Carburetor Adjustment, Open the choke: 步骤 4 中的图像 2,3 Carburetor Adjustment, Open the choke: 步骤 4 中的图像 3,3
    • Make sure the choke is fully in the open position.
  5. Carburetor Adjustment: 步骤 5 中的图像 1,2 Carburetor Adjustment: 步骤 5 中的图像 2,2
    • Use a Phillips screwdriver to adjust the carburetor idle screw until the tachometer reads as close to 3100 RPM as possible:
    • Turn the idle screw clockwise to increase RPM
    • Turn the idle screw counterclockwise to decrease RPM
    • Once the idle has been set, shut off the motor and disconnect the tachometer.
结论
The procedure is complete, no further action is required.
2等其他人完成本指南。
Sam Omiotek
于02/25/19注册
95,636 声望
创作了290篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 26
总计 815
