跳转到主内容
加入维修社区 - 创建账户
Car audio KDC-BT44U firmware update
你所需要的
      • Download the latest firmware from Kenwood
      • Copy the firmware to the USB stick in the root directory
      • Insert the USB stick into the USB port of the radio. (Front or cable on the back doesn't matter)
      • Make sure the radio recognizes the USB stick. E.g. If there is an mp3 file on the USB stick, this can be tested by simply playing the MP3. This ensures that the USB stick is correctly formatted.
      询问修复机器人
      添加评论
    1. Car audio KDC-BT44U firmware update, Perform normal update: 步骤 2 中的图像 1,2 Car audio KDC-BT44U firmware update, Perform normal update: 步骤 2 中的图像 2,2
      • Use the "SRC" button to put the radio in "STANDBY" mode.
      • Display the menu by pressing the volume knob.
      • Select the item "SYSTEM" and press the volume button.
      • Then select the item "F/W UPDATE" and press the volume button.
      • Then select "UPDATE SYSTEM" and press the volume button twice.
      • Then select "YES" and press the volume button.
      询问修复机器人
      添加评论
      • The radio switches itself off briefly and then back on again
      • The display shows "UPDATING".
      • after approx. 5 minutes the display shows "COMPLETED".
      询问修复机器人
      添加评论
    2. Car audio KDC-BT44U firmware update, Completion: 步骤 4 中的图像 1,1
      • You can only continue here when "COMPLETED" is displayed
      • Detach the front panel with the release button on the bottom left
      • Press the reset button in the radio body
      • Reattach the front panel
      • If the radio is now switched on again with the "SRC" button, the DEMO mode should start and the update should be completed.
      • All old settings can now be set again.
      询问修复机器人
      添加评论
结论
Possible problems:
  1. In the normal mode of the radio, when the “UPDATE SYSTEM” is activated, “FILE CHECKING” is displayed very briefly and then “NO FILE”.
    Cause: a) The USB stick is not formatted in the appropriate format (-> FAT32 or FAT16 are good)
    b) The correct firmware update file is not stored directly in the root directory of the USB stick (only the file name is checked -> for a radio type only one firmware file name is evaluated as valid)
  2. After the automatic switching off and on, first “WAIT” appears, then “FILE CHECKING” and then “NO FILE”.
    Cause: Firmware filename verification is different between normal radio mode and update mode.
    This case is fatal because you can no longer return to radio mode without having imported a valid update...
Solutions:
Are described in the attached PDF to avoid the character limit here.
取消:我没有完成这个指南。
2等其他人完成本指南。
由衷感谢以下译者:
de en
100%
HelloMacOS正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
附加文件
RadioWastler
于01/01/21注册
169 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 34
总计 1,224
