跳转到主内容
加入维修社区 - 创建账户
Car Seat Belt Stopper Replacement
你所需要的
  1. Car Seat Belt Stopper Replacement, Car Seat Belt Stopper: 步骤 1 中的图像 1,1
    • Use a cloth to wipe away any debris from the area.
    询问修复机器人
    添加评论
  2. Car Seat Belt Stopper Replacement: 步骤 2 中的图像 1,1
    • Find the existing hole for the seat belt stopper or choose a different location that is better for you.
    • Separate the replacement stopper if it has come assembled.
    询问修复机器人
    添加评论
  3. Car Seat Belt Stopper Replacement: 步骤 3 中的图像 1,1
    • Before you begin, make sure that the seat belt buckle is pushed above the hole where you are installing the new seat belt stopper.
    • Push the side of the seat belt button with the needle or point into your desired location.
    • It may require a small amount of force.
    询问修复机器人
    添加评论
  4. Car Seat Belt Stopper Replacement: 步骤 4 中的图像 1,1
    • Take the other half of button stopper and slide it onto the pin on the other side of the belt.
    • Fasten the two parts of the button together and squeeze for a secure fit.
    • You may hear a "snap" or "click" when they are fastened together.
    询问修复机器人
    添加评论
  5. Car Seat Belt Stopper Replacement: 步骤 5 中的图像 1,1
    • Check the position of the replacement stopper for a comfortable fit.
    询问修复机器人
    添加评论
  6. Car Seat Belt Stopper Replacement: 步骤 6 中的图像 1,1
    • Now you can use the seat belt buckle without it falling down!
    添加评论
结论
Changing your positioning of replacement can be used to your liking.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Zhong Chu
于04/23/24注册
137 声望
撰写一个指南
团队
UC Davis, Team 4-1, Whithaus Spring 2024 UC Davis, Team 4-1, Whithaus Spring 2024 的会员
UCD-WHITHAUS-S24S4G1
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 150
总计 3,042
