跳转到主内容
Capresso Perfectea 260 Motherboard Replacement
你所需要的
  1. Capresso Perfectea 260 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • First, take the base of the device and flip it over.
  2. Capresso Perfectea 260 Motherboard Replacement: 步骤 2 中的图像 1,2 Capresso Perfectea 260 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
  3. Capresso Perfectea 260 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
  4. Capresso Perfectea 260 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Unplug the wire going into the side of the motherboard
  5. Capresso Perfectea 260 Motherboard Replacement: 步骤 5 中的图像 1,2 Capresso Perfectea 260 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
    • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
    • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
  6. Capresso Perfectea 260 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Lift the motherboard out of the device
结论
Rohin Chander
于04/14/15注册
101 声望
撰写一个指南
团队
Cal Poly, Team 6-17, Maness Spring 2015 Cal Poly, Team 6-17, Maness Spring 2015 的会员
CPSU-MANESS-S15S6G17
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 238
