跳转到主内容
Capresso Perfectea 260 Lid Replacement
你所需要的
  1. Capresso Perfectea 260 Lid Replacement, Lid: 步骤 1 中的图像 1,1
    • Lift the lid of the Perfectea
    • Remove the two 12mm Phillips #2 screws located at the brim of the pot.
  2. Capresso Perfectea 260 Lid Replacement: 步骤 2 中的图像 1,3 Capresso Perfectea 260 Lid Replacement: 步骤 2 中的图像 2,3 Capresso Perfectea 260 Lid Replacement: 步骤 2 中的图像 3,3
    • Adhesive tape is left holding the lid to the glass pot.
    • Use the spudger for this step.
    • With one hand, firmly grip the lid while designating your other hand to wedge the spudger between the lid and the glass pot.
    • Working from the outside to the inside, gently pry the adhesive tape from the glass pot, detaching the lid.
结论
另外一个人完成了本指南。
Kenji Anzai
于04/14/15注册
588 声望
创作了4篇指南
团队
Cal Poly, Team 6-17, Maness Spring 2015 Cal Poly, Team 6-17, Maness Spring 2015 的会员
CPSU-MANESS-S15S6G17
4 名成员
创作了6篇指南
一条评论
This guide applies to the Capresso H2O kettle too. Thanks for the guide.
Giovanni Ciriani - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 649
