简介
The lens of the Canon ZR70MC is the most difficult component to replace. There are many steps in this guide so make sure that you allow yourself adequate time to complete this replacement guide. There are also many small parts so make sure to have a designated area to keep the parts that you take off. This guide will show you how to gain access to and replace the lens of the camcorder. Do not damage any films or wire that you come across.
你所需要的
Locate the four 3.5 mm screws on the top of the camcorder that holds the lens in place.
Remove the four 3.5 mm screws.
Remove the metal plate that the screws were holding down.
Use the tweezers to pull the green circuit board away from the main body of the camcorder.
Pull out the white wire from its connection so that the green circuit board can be completely removed form the main body of the camcorder.
Removing this green circuit board allows access to the camcorder lens.
