跳转到主内容
Canon ZR70MC Front Panel Replacement
你所需要的
  1. Canon ZR70MC Front Panel Replacement, Front Panel: 步骤 1 中的图像 1,2 Canon ZR70MC Front Panel Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Unscrew the 3.35mm screw.
  2. Canon ZR70MC Front Panel Replacement: 步骤 2 中的图像 1,1
    • Turn the ZR70MC so that you can see the bottom of the camcorder.
    • Unscrew the 3.35 mm located in the top left portion of the camera.
  3. Canon ZR70MC Front Panel Replacement: 步骤 3 中的图像 1,3 Canon ZR70MC Front Panel Replacement: 步骤 3 中的图像 2,3 Canon ZR70MC Front Panel Replacement: 步骤 3 中的图像 3,3
    • Turn the camera on the side and remove the cover for the audio inputs. There is a 2.65 mm screw located behind the cover.
    • Remove the 2.65 mm screw.
  4. Canon ZR70MC Front Panel Replacement: 步骤 4 中的图像 1,3 Canon ZR70MC Front Panel Replacement: 步骤 4 中的图像 2,3 Canon ZR70MC Front Panel Replacement: 步骤 4 中的图像 3,3
    • Remove the cover located on the front of the camcorder and remove the cover by pulling on the bottom groove.
    • Locate and remove the two 3.35 mm screws.
  5. Canon ZR70MC Front Panel Replacement: 步骤 5 中的图像 1,2 Canon ZR70MC Front Panel Replacement: 步骤 5 中的图像 2,2
    • Turn the camcorder so that the bottom is facing up and open the tape cassette compartment.
    • There is one 3.35 mm screw located under the tape cassette panel on the front left side of the camcorder. Remove the screw.
  6. Canon ZR70MC Front Panel Replacement: 步骤 6 中的图像 1,3 Canon ZR70MC Front Panel Replacement: 步骤 6 中的图像 2,3 Canon ZR70MC Front Panel Replacement: 步骤 6 中的图像 3,3
    • Now that all of the screws are removed, remove the front panel by gently pulling on the front panel.
    • The speaker will be connected to the main body by a wire. Be careful not to damage this wire.
  7. Canon ZR70MC Front Panel Replacement: 步骤 7 中的图像 1,3 Canon ZR70MC Front Panel Replacement: 步骤 7 中的图像 2,3 Canon ZR70MC Front Panel Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to gently pull the speaker wire from the main body of the camcorder.
    • Pull the front panel completely away from the main body of the camcorder.
结论
另外一个人完成了本指南。
khalid clarke
于09/26/17注册
824 声望
创作了7篇指南
团队
USF Tampa, Team S13-G2, Boczar Fall 2017 USF Tampa, Team S13-G2, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S13G2
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 198
