跳转到主内容
Canon Vixia HF20 Camcorder Strap Replacement
  1. Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: 步骤 1 中的图像 1,3 Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: 步骤 1 中的图像 2,3 Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: 步骤 1 中的图像 3,3
    • Un-velcro the camcorder strap.
    • Remove the strap from the first hole by pulling towards the front of the camcorder, continue pulling the strap through until it is removed from second anchor point as well.
    • There should now be two empty anchor points.
  2. Canon Vixia HF20 Camcorder Strap Replacement: 步骤 2 中的图像 1,3 Canon Vixia HF20 Camcorder Strap Replacement: 步骤 2 中的图像 2,3 Canon Vixia HF20 Camcorder Strap Replacement: 步骤 2 中的图像 3,3
    • Re-insert the new Velcro strap through the back anchor hole in the direction of the arrow (toward the battery end of the camcorder).
    • Then through the padded hand strap in direction of the arrow.
    • Lastly, pull the strap through the front anchor hole adjusting for your grip.
  3. Canon Vixia HF20 Camcorder Strap Replacement: 步骤 3 中的图像 1,1
    • Once the fit is adjusted, secure by closing the padded strap.
终点
另外一个人完成了本指南。
Taylor Morris
于03/05/15注册
225 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 556
