跳转到主内容
Canon Vixia HF S10 Camcorder Audio Replacement
你所需要的
  1. Canon Vixia HF S10 Camcorder Audio Replacement, Audio: 步骤 1 中的图像 1,3 Canon Vixia HF S10 Camcorder Audio Replacement, Audio: 步骤 1 中的图像 2,3 Canon Vixia HF S10 Camcorder Audio Replacement, Audio: 步骤 1 中的图像 3,3
    • Turn the camcorder upside down and remove the three 3x4 mm Phillips screws securing the black plastic case.
    • Flip open the LCD screen.
    • Remove the three 3x4 mm Phillips screws securing the black panel plastic case.
  2. Canon Vixia HF S10 Camcorder Audio Replacement: 步骤 2 中的图像 1,3 Canon Vixia HF S10 Camcorder Audio Replacement: 步骤 2 中的图像 2,3 Canon Vixia HF S10 Camcorder Audio Replacement: 步骤 2 中的图像 3,3
    • From the inner corner in between the panel and the LCD screen, remove the two 2x2.5 mm Phillips screws and the 3x4 mm Phillips screw.
    • Remove the black plastic covering with your fingers. Underneath the covering, you will find a screw hinge.
    • Remove the 2x2.25 mm Phillips screw located at the top of the screw hinge.
  3. Canon Vixia HF S10 Camcorder Audio Replacement: 步骤 3 中的图像 1,3 Canon Vixia HF S10 Camcorder Audio Replacement: 步骤 3 中的图像 2,3 Canon Vixia HF S10 Camcorder Audio Replacement: 步骤 3 中的图像 3,3
    • Using your fingers, remove the panel from the base of the camcorder.
    • After removing the panel, remove the two 2x2.25 mm Phillips screws located at the top right of the inside of the panel.
    • Using one hand, gently move the silver piece holding the speaker down while using the other hand to remove the speaker.
结论
Clint
于03/03/15注册
101 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 420
