跳转到主内容
Canon Vixia HF R70 Lens Replacement
你所需要的
  1. Canon Vixia HF R70 Lens Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off and unplug the device.
    • Position the camera so that the battery is facing you.
  2. Canon Vixia HF R70 Lens Replacement: 步骤 2 中的图像 1,1
    • Locate the latch on the bottom edge of the camera.
    • Hold the battery into place and gently push down on the latch towards the lens.
  3. Canon Vixia HF R70 Lens Replacement: 步骤 3 中的图像 1,2 Canon Vixia HF R70 Lens Replacement: 步骤 3 中的图像 2,2
    • While holding down the latch, remove the battery by pulling it out of the device.
  4. Canon Vixia HF R70 Lens Replacement, Wrist Strap: 步骤 4 中的图像 1,1
    • Position the camcorder so that the wrist strap is facing you.
    • Locate the loose end of the strap.
  5. Canon Vixia HF R70 Lens Replacement: 步骤 5 中的图像 1,1
    • Gently pull on the loose end to separate the Velcro.
  6. Canon Vixia HF R70 Lens Replacement: 步骤 6 中的图像 1,1
    • Locate the "slot" on bottom right corner of the camcorder where the strap loops through.
    • Pull the strap through the loop.
  7. Canon Vixia HF R70 Lens Replacement: 步骤 7 中的图像 1,2 Canon Vixia HF R70 Lens Replacement: 步骤 7 中的图像 2,2
    • Pull the strap through the leather cushion.
  8. Canon Vixia HF R70 Lens Replacement: 步骤 8 中的图像 1,1
    • Pull the strap through the slot on the left side of the camcorder.
  9. Canon Vixia HF R70 Lens Replacement, Side Panel: 步骤 9 中的图像 1,2 Canon Vixia HF R70 Lens Replacement, Side Panel: 步骤 9 中的图像 2,2
    • Position the camcorder so that the side panel is facing you.
    • Locate the two 6mm Phillips #00 screws on the side panel.
    • Remove the the screws using a screwdriver with a Phillips #00 head.
  10. Canon Vixia HF R70 Lens Replacement: 步骤 10 中的图像 1,3 Canon Vixia HF R70 Lens Replacement: 步骤 10 中的图像 2,3 Canon Vixia HF R70 Lens Replacement: 步骤 10 中的图像 3,3
    • Turn the camcorder so that the bottom is facing you.
    • Using your screwdriver, locate and remove the four 6mm Phillips #00 screws connecting the side panel to the bottom of the camcorder.
  11. Canon Vixia HF R70 Lens Replacement: 步骤 11 中的图像 1,2 Canon Vixia HF R70 Lens Replacement: 步骤 11 中的图像 2,2
    • Gently remove the side panel by pushing it up from the bottom.
  12. Canon Vixia HF R70 Lens Replacement, Top Panel: 步骤 12 中的图像 1,2 Canon Vixia HF R70 Lens Replacement, Top Panel: 步骤 12 中的图像 2,2
    • Disconnect the wires by inserting the plastic opening tool into the small slit.
    • Begin to push upward with the plastic opening tool, disconnecting the two compartments.
  13. Canon Vixia HF R70 Lens Replacement: 步骤 13 中的图像 1,3 Canon Vixia HF R70 Lens Replacement: 步骤 13 中的图像 2,3 Canon Vixia HF R70 Lens Replacement: 步骤 13 中的图像 3,3
    • Disconnect the four ZIF connectors by grasping the connector firmly and pulling gently.
  14. Canon Vixia HF R70 Lens Replacement: 步骤 14 中的图像 1,1
    • Locate and remove the two 3mm Phillips #00 screws on the side of the camera where the side panel was removed.
  15. Canon Vixia HF R70 Lens Replacement: 步骤 15 中的图像 1,1
    • Turn the camera over to the side with the LCD screen, and open the screen.
    • Locate and remove the three 5mm Phillips #00 screws holding the top panel in place.
  16. Canon Vixia HF R70 Lens Replacement: 步骤 16 中的图像 1,3 Canon Vixia HF R70 Lens Replacement: 步骤 16 中的图像 2,3 Canon Vixia HF R70 Lens Replacement: 步骤 16 中的图像 3,3
    • Pull the panel up and away until it is removed completely.
  17. Canon Vixia HF R70 Lens Replacement, Shutter: 步骤 17 中的图像 1,3 Canon Vixia HF R70 Lens Replacement, Shutter: 步骤 17 中的图像 2,3 Canon Vixia HF R70 Lens Replacement, Shutter: 步骤 17 中的图像 3,3
    • There are three 5mm Phillips #00 screws that need to be removed - one on the top, one on the side, and one on the bottom.
    • Locate and remove the screw on the top side of the camera.
    • Locate and remove the screw on the side of the camera where you previously removed the side panel.
    • Locate and remove the screw on the bottom of the camera.
  18. Canon Vixia HF R70 Lens Replacement: 步骤 18 中的图像 1,2 Canon Vixia HF R70 Lens Replacement: 步骤 18 中的图像 2,2
    • Pull the entire shutter away from the body of the camera to remove it.
  19. Canon Vixia HF R70 Lens Replacement, Lens: 步骤 19 中的图像 1,2 Canon Vixia HF R70 Lens Replacement, Lens: 步骤 19 中的图像 2,2
    • With the front of the camera facing you, locate and remove the three 5mm Phillips #00 screws that hold the lens in place.
  20. Canon Vixia HF R70 Lens Replacement: 步骤 20 中的图像 1,3 Canon Vixia HF R70 Lens Replacement: 步骤 20 中的图像 2,3 Canon Vixia HF R70 Lens Replacement: 步骤 20 中的图像 3,3
    • Grasp the plastic sides of the lens, and pull it away from the camera body to finish removing the lens.
结论
Kristin Pitts
于02/28/17注册
201 声望
创作了2篇指南
团队
USF Tampa, Team S2-G2, Nance Spring 2017 USF Tampa, Team S2-G2, Nance Spring 2017 的会员
USFT-NANCE-S17S2G2
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 606
