跳转到主内容
Canon Vixia HF R62 Outer Casing Replacement
你所需要的
  1. Canon Vixia HF R62 Outer Casing Replacement, Outer Shell: 步骤 1 中的图像 1,2 Canon Vixia HF R62 Outer Casing Replacement, Outer Shell: 步骤 1 中的图像 2,2
    • Remove the strap by undoing the Velcro and pulling it through the thread points.
    • Remove the external battery pack by pressing down on the slide release and sliding it out.
  2. Canon Vixia HF R62 Outer Casing Replacement: 步骤 2 中的图像 1,2 Canon Vixia HF R62 Outer Casing Replacement: 步骤 2 中的图像 2,2
    • Remove the three 5mm Phillips #000 screws on the bottom of the device.
  3. Canon Vixia HF R62 Outer Casing Replacement: 步骤 3 中的图像 1,2 Canon Vixia HF R62 Outer Casing Replacement: 步骤 3 中的图像 2,2
    • On the side of the device, remove the following Phillips #000 screws:
    • One 3mm screw
    • One 5mm screw
  4. Canon Vixia HF R62 Outer Casing Replacement: 步骤 4 中的图像 1,2 Canon Vixia HF R62 Outer Casing Replacement: 步骤 4 中的图像 2,2
    • Remove the panel opposite the display by pulling up perpendicular to the side.
  5. Canon Vixia HF R62 Outer Casing Replacement: 步骤 5 中的图像 1,1
    • Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
  6. Canon Vixia HF R62 Outer Casing Replacement: 步骤 6 中的图像 1,2 Canon Vixia HF R62 Outer Casing Replacement: 步骤 6 中的图像 2,2
    • Remove the three 4mm Phillips #000 screws shown.
    • There will be foam covers protecting some or all of these screws. These will need to be removed before you will be able to unscrew them.
  7. Canon Vixia HF R62 Outer Casing Replacement: 步骤 7 中的图像 1,3 Canon Vixia HF R62 Outer Casing Replacement: 步骤 7 中的图像 2,3 Canon Vixia HF R62 Outer Casing Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using tweezers, disconnect this ribbon cable by pulling straight out.
  8. Canon Vixia HF R62 Outer Casing Replacement: 步骤 8 中的图像 1,3 Canon Vixia HF R62 Outer Casing Replacement: 步骤 8 中的图像 2,3 Canon Vixia HF R62 Outer Casing Replacement: 步骤 8 中的图像 3,3
    • Repeat step seven (7) for the remaining three wires shown.
  9. Canon Vixia HF R62 Outer Casing Replacement: 步骤 9 中的图像 1,3 Canon Vixia HF R62 Outer Casing Replacement: 步骤 9 中的图像 2,3 Canon Vixia HF R62 Outer Casing Replacement: 步骤 9 中的图像 3,3
    • Grasp the top of the camera and pull straight up to remove the top panel.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 7
总计 133
