跳转到主内容
Canon Vixia HF R62 Display Panel Replacement
你所需要的
  1. Canon Vixia HF R62 Display Panel Replacement, Outer Shell: 步骤 1 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement, Outer Shell: 步骤 1 中的图像 2,2
    • Remove the strap by undoing the Velcro and pulling it through the thread points.
    • Remove the external battery pack by pressing down on the slide release and sliding it out.
  2. Canon Vixia HF R62 Display Panel Replacement: 步骤 2 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 2 中的图像 2,2
    • Remove the three 5mm Phillips #000 screws on the bottom of the device.
  3. Canon Vixia HF R62 Display Panel Replacement: 步骤 3 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 3 中的图像 2,2
    • On the side of the device, remove the following Phillips #000 screws:
    • One 3mm screw
    • One 5mm screw
  4. Canon Vixia HF R62 Display Panel Replacement: 步骤 4 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 4 中的图像 2,2
    • Remove the panel opposite the display by pulling up perpendicular to the side.
  5. Canon Vixia HF R62 Display Panel Replacement: 步骤 5 中的图像 1,1
    • Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
  6. Canon Vixia HF R62 Display Panel Replacement: 步骤 6 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 6 中的图像 2,2
    • Remove the three 4mm Phillips #000 screws shown.
    • There will be foam covers protecting some or all of these screws. These will need to be removed before you will be able to unscrew them.
  7. Canon Vixia HF R62 Display Panel Replacement: 步骤 7 中的图像 1,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 7 中的图像 2,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using tweezers, disconnect this ribbon cable by pulling straight out.
  8. Canon Vixia HF R62 Display Panel Replacement: 步骤 8 中的图像 1,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 8 中的图像 2,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 8 中的图像 3,3
    • Repeat step seven (7) for the remaining three wires shown.
  9. Canon Vixia HF R62 Display Panel Replacement: 步骤 9 中的图像 1,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 9 中的图像 2,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 9 中的图像 3,3
    • Grasp the top of the camera and pull straight up to remove the top panel.
  10. Canon Vixia HF R62 Display Panel Replacement, Lens: 步骤 10 中的图像 1,1
    • Remove the 5mm Phillips #000 screw on top of the inner case.
  11. Canon Vixia HF R62 Display Panel Replacement: 步骤 11 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 11 中的图像 2,2
    • Remove the two 5mm Phillips #000 screws near the display panel.
  12. Canon Vixia HF R62 Display Panel Replacement: 步骤 12 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 12 中的图像 2,2
    • Disconnect the small bundled cable connector on the side of the lens cover by pulling it straight out.
  13. Canon Vixia HF R62 Display Panel Replacement: 步骤 13 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 13 中的图像 2,2
    • Remove the lens cover by pulling straight away from the body.
  14. Canon Vixia HF R62 Display Panel Replacement: 步骤 14 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 14 中的图像 2,2
    • Remove the three 6mm Phillips #000 screws shown.
  15. Canon Vixia HF R62 Display Panel Replacement: 步骤 15 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 15 中的图像 2,2
    • Remove the lens by pulling straight away from the main body.
    • Be aware of the small rubber gasket around the lens as it may come loose.
  16. Canon Vixia HF R62 Display Panel Replacement, Internal Battery and SD Card Reader: 步骤 16 中的图像 1,3 Canon Vixia HF R62 Display Panel Replacement, Internal Battery and SD Card Reader: 步骤 16 中的图像 2,3 Canon Vixia HF R62 Display Panel Replacement, Internal Battery and SD Card Reader: 步骤 16 中的图像 3,3
    • Remove the two 3mm Phillips #000 screws.
    • Remove the 4mm Phillips #000 screw.
  17. Canon Vixia HF R62 Display Panel Replacement: 步骤 17 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 17 中的图像 2,2
    • Disconnect the ribbon cable shown.
  18. Canon Vixia HF R62 Display Panel Replacement: 步骤 18 中的图像 1,1
    • Remove the 4mm Phillips #000 screw at the bottom of the camera.
  19. Canon Vixia HF R62 Display Panel Replacement: 步骤 19 中的图像 1,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 19 中的图像 2,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 19 中的图像 3,3
    • Place the spudger under the tab shown.
    • While prying the tab up with the spudger, pull the case away.
  20. Canon Vixia HF R62 Display Panel Replacement, Central Capturing Unit: 步骤 20 中的图像 1,3 Canon Vixia HF R62 Display Panel Replacement, Central Capturing Unit: 步骤 20 中的图像 2,3 Canon Vixia HF R62 Display Panel Replacement, Central Capturing Unit: 步骤 20 中的图像 3,3
    • Using a spudger, disconnect the ribbon cable connector from the PC board shown in the picture.
  21. Canon Vixia HF R62 Display Panel Replacement: 步骤 21 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 21 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using tweezers, disconnect the ribbon cable shown in the picture by pulling straight out.
  22. Canon Vixia HF R62 Display Panel Replacement: 步骤 22 中的图像 1,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 22 中的图像 2,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 22 中的图像 3,3
    • Using a spudger, gently pry up the top tab on the ZIF connector. The wire will now disconnect with no force needed.
    • When reassembling you will need to place the ribbon wire tightly against the tab in order to properly secure it.
  23. Canon Vixia HF R62 Display Panel Replacement: 步骤 23 中的图像 1,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 23 中的图像 2,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 23 中的图像 3,3
    • Using your fingers, firmly grasp both ends of the capturing device and gently pull the assembly straight out.
  24. Canon Vixia HF R62 Display Panel Replacement, Display Panel: 步骤 24 中的图像 1,1
    • Remove the 3mm Phillips #000 screw holding the display's ribbon wire to the casing.
  25. Canon Vixia HF R62 Display Panel Replacement: 步骤 25 中的图像 1,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 25 中的图像 2,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 25 中的图像 3,3
    • Undo the ZIF connector from the motherboard using a plastic spudger. Use the spudger to pry the small tab on top of the ZIF connector and the ribbon cable will fall free.
    • When reassembling, you will need to place the ribbon cable tightly against the tab in order to properly secure it.
  26. Canon Vixia HF R62 Display Panel Replacement: 步骤 26 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 26 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • There is a small component of the ribbon cable clipped to the casing. Remove this by pulling it away from the casing with tweezers.
    • Some of the ribbon may become entangled in the clips that held the component. Ensure they are untangled before the display is removed to avoid damage.
  27. Canon Vixia HF R62 Display Panel Replacement: 步骤 27 中的图像 1,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 27 中的图像 2,3 Canon Vixia HF R62 Display Panel Replacement: 步骤 27 中的图像 3,3
    • The ribbon cable is also looped around a piece of the casing under the motherboard. Unfasten this cable with tweezers by sliding down and then pulling out.
  28. Canon Vixia HF R62 Display Panel Replacement: 步骤 28 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 28 中的图像 2,2
    • Open the display panel.
    • This will help during the reassembly as one of the hinges locks in place and is difficult to reassemble if in the closed position.
  29. Canon Vixia HF R62 Display Panel Replacement: 步骤 29 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 29 中的图像 2,2
    • Remove the two 3mm Phillips #000 screws connecting to the display panel's hinges.
  30. Canon Vixia HF R62 Display Panel Replacement: 步骤 30 中的图像 1,2 Canon Vixia HF R62 Display Panel Replacement: 步骤 30 中的图像 2,2
    • Remove the display panel by pulling the display straight away from the body.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 8
总计 282
