简介
This guide will show you how to access and replace the heart of this camcorder, the central capturing unit assembly.
你所需要的
Remove the strap by undoing the Velcro and pulling it through the thread points.
Remove the external battery pack by pressing down on the slide release and sliding it out.
Remove the two 3mm Phillips #000 screws.
Remove the 4mm Phillips #000 screw.
Using a spudger, disconnect the ribbon cable connector from the PC board shown in the picture.
即将完成!
To reassemble the central capturing unit, follow these instructions in reverse order.
结论
