跳转到主内容
Canon Vixia HF R600 Speaker Replacement
你所需要的
  1. Canon Vixia HF R600 Speaker Replacement, Handstrap: 步骤 1 中的图像 1,2 Canon Vixia HF R600 Speaker Replacement, Handstrap: 步骤 1 中的图像 2,2
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 Speaker Replacement: 步骤 2 中的图像 1,2 Canon Vixia HF R600 Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 Speaker Replacement, Battery: 步骤 3 中的图像 1,2 Canon Vixia HF R600 Speaker Replacement, Battery: 步骤 3 中的图像 2,2
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 Speaker Replacement, Casing: 步骤 4 中的图像 1,2 Canon Vixia HF R600 Speaker Replacement, Casing: 步骤 4 中的图像 2,2
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
  5. Canon Vixia HF R600 Speaker Replacement: 步骤 5 中的图像 1,2 Canon Vixia HF R600 Speaker Replacement: 步骤 5 中的图像 2,2
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 Speaker Replacement: 步骤 6 中的图像 1,2 Canon Vixia HF R600 Speaker Replacement: 步骤 6 中的图像 2,2
    • Gently pull the plastic casing away from the camera.
  7. Canon Vixia HF R600 Speaker Replacement, Speaker: 步骤 7 中的图像 1,2 Canon Vixia HF R600 Speaker Replacement, Speaker: 步骤 7 中的图像 2,2
    • Remove one 4mm Phillips JIS#00 screw on the right side of the camera.
    • Use the plastic opening tool to undo the bronze ribbon connector.
  8. Canon Vixia HF R600 Speaker Replacement: 步骤 8 中的图像 1,2 Canon Vixia HF R600 Speaker Replacement: 步骤 8 中的图像 2,2
    • Remove one 4mm Phillips JIS#00 screw located on the top of the camera near the battery connection.
    • Pull the plastic casing away from the camera. The speaker and power button are housed in this casing.
  9. Canon Vixia HF R600 Speaker Replacement: 步骤 9 中的图像 1,2 Canon Vixia HF R600 Speaker Replacement: 步骤 9 中的图像 2,2
    • Remove four 5mm Phillips PH#00 screws holding the speaker bracket in place.
    • Remove one more 5mm screw below the power button.
  10. Canon Vixia HF R600 Speaker Replacement: 步骤 10 中的图像 1,2 Canon Vixia HF R600 Speaker Replacement: 步骤 10 中的图像 2,2
    • Carefully pull the speaker out of the casing.
结论
Logan Coats
于02/10/16注册
522 声望
创作了4篇指南
团队
USF Tampa, Team 14-4, Lacy Spring 2016 USF Tampa, Team 14-4, Lacy Spring 2016 的会员
USFT-LACY-S16S14G4
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 274
