跳转到主内容
Canon Vixia HF R500 Microphone Replacement
你所需要的
  1. Canon Vixia HF R500 Microphone Replacement, Grip Belt: 步骤 1 中的图像 1,3 Canon Vixia HF R500 Microphone Replacement, Grip Belt: 步骤 1 中的图像 2,3 Canon Vixia HF R500 Microphone Replacement, Grip Belt: 步骤 1 中的图像 3,3
    • On the right side of the camcorder remove the grip belt.
  2. Canon Vixia HF R500 Microphone Replacement, Battery: 步骤 2 中的图像 1,1
    • Hold on to the battery.
  3. Canon Vixia HF R500 Microphone Replacement: 步骤 3 中的图像 1,1
    • On the bottom of the battery hold the battery release switch.
  4. Canon Vixia HF R500 Microphone Replacement: 步骤 4 中的图像 1,1
    • Remove the battery slowly away from the camcorder.
    • Removing the battery quick or in a different angle may cause sparks and damage to device.
  5. Canon Vixia HF R500 Microphone Replacement, Canon Vixia HF R500 Disassembly: 步骤 5 中的图像 1,2 Canon Vixia HF R500 Microphone Replacement, Canon Vixia HF R500 Disassembly: 步骤 5 中的图像 2,2
    • Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
  6. Canon Vixia HF R500 Microphone Replacement: 步骤 6 中的图像 1,1
    • Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
    • A hidden 4mm Philips #000 screw is shown under the black plug shown.
  7. Canon Vixia HF R500 Microphone Replacement: 步骤 7 中的图像 1,1
    • Remove the side piece plate.
  8. Canon Vixia HF R500 Microphone Replacement: 步骤 8 中的图像 1,1
    • Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
  9. Canon Vixia HF R500 Microphone Replacement: 步骤 9 中的图像 1,1
    • Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
    • Do not use strong magnetic parts on the inside, as they may damage the device.
  10. Canon Vixia HF R500 Microphone Replacement: 步骤 10 中的图像 1,1
    • Using the spudger, pull the tab shown to start removing the ribbon cable.
  11. Canon Vixia HF R500 Microphone Replacement: 步骤 11 中的图像 1,3 Canon Vixia HF R500 Microphone Replacement: 步骤 11 中的图像 2,3 Canon Vixia HF R500 Microphone Replacement: 步骤 11 中的图像 3,3
    • Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
  12. Canon Vixia HF R500 Microphone Replacement: 步骤 12 中的图像 1,1
    • Remove the top piece.
  13. Canon Vixia HF R500 Microphone Replacement, Lens Cover: 步骤 13 中的图像 1,1
    • Remove the two 5mm Phillips #000 screws near the LCD screen.
  14. Canon Vixia HF R500 Microphone Replacement: 步骤 14 中的图像 1,1
    • Remove the single 5mm Phillips #000 screw located on the top of the camera near the lens cover.
  15. Canon Vixia HF R500 Microphone Replacement: 步骤 15 中的图像 1,1
    • Unplug the cord connecting the camera to the lens cover. Grip the white plug near the port and pull it out.
    • Do not pull the cord by the wires. Grip the white plastic plug.
  16. Canon Vixia HF R500 Microphone Replacement: 步骤 16 中的图像 1,1
    • The lens cover is detached from the camera and can now be removed.
    • Repair or replace damaged components in the lens cover.
    • Ensure lens cover mechanism is free of debris.
  17. Canon Vixia HF R500 Microphone Replacement, Microphone: 步骤 17 中的图像 1,1
    • Remove one 5mm Philips #000 screw from the lens cap.
  18. Canon Vixia HF R500 Microphone Replacement: 步骤 18 中的图像 1,1
    • Remove the lens cover and place in a safe place.
  19. Canon Vixia HF R500 Microphone Replacement: 步骤 19 中的图像 1,1
    • Remove the one 3mm Philips #000 screw that holds the microphone in place.
  20. Canon Vixia HF R500 Microphone Replacement: 步骤 20 中的图像 1,1
    • Remove the metal plate that holds the microphone.
  21. Canon Vixia HF R500 Microphone Replacement: 步骤 21 中的图像 1,1
    • Remove the defective microphone out of the lens cap.
  22. Canon Vixia HF R500 Microphone Replacement: 步骤 22 中的图像 1,1
    • Insert the new microphone in the same place.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 163
