跳转到主内容
Canon Vixia HF R500 Disassembly
你所需要的
  1. Canon Vixia HF R500 Disassembly, Canon Vixia HF R500 Disassembly: 步骤 1 中的图像 1,2 Canon Vixia HF R500 Disassembly, Canon Vixia HF R500 Disassembly: 步骤 1 中的图像 2,2
    • Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
  2. Canon Vixia HF R500 Disassembly: 步骤 2 中的图像 1,1
    • Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
    • A hidden 4mm Philips #000 screw is shown under the black plug shown.
  3. Canon Vixia HF R500 Disassembly: 步骤 3 中的图像 1,1
    • Remove the side piece plate.
  4. Canon Vixia HF R500 Disassembly: 步骤 4 中的图像 1,1
    • Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
  5. Canon Vixia HF R500 Disassembly: 步骤 5 中的图像 1,1
    • Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
    • Do not use strong magnetic parts on the inside, as they may damage the device.
  6. Canon Vixia HF R500 Disassembly: 步骤 6 中的图像 1,1
    • Using the spudger, pull the tab shown to start removing the ribbon cable.
  7. Canon Vixia HF R500 Disassembly: 步骤 7 中的图像 1,3 Canon Vixia HF R500 Disassembly: 步骤 7 中的图像 2,3 Canon Vixia HF R500 Disassembly: 步骤 7 中的图像 3,3
    • Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
  8. Canon Vixia HF R500 Disassembly: 步骤 8 中的图像 1,1
    • Remove the top piece.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 662
