跳转到主内容
Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement
你所需要的
  1. Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement, Mode-Selection Wheel: 步骤 1 中的图像 1,1
    • Push down on the black switch located on the side of the camera. This will cause the back of the camera to pop open.
  2. Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 步骤 2 中的图像 1,2 Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 步骤 2 中的图像 2,2
    • Remove the five screws circled in red from the plastic on the back of the camera.
  3. Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 步骤 3 中的图像 1,2 Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 步骤 3 中的图像 2,2
    • Pull on the metallic piece that is sticking out from underneath the plastic. This will allow you to remove both the piece of black plastic and the metallic piece from the camera.
  4. Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 步骤 4 中的图像 1,1
    • You should now see the a strip of black plastic covering the back of the display's logic board. Remove the screw circled in red.
  5. Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 步骤 5 中的图像 1,2 Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 步骤 5 中的图像 2,2
    • Pull on the orange cable connected to the logic board to lift the logic board out of place.
    • Move the logic board out of the way, as it is covering the screw that holds the wheel in place.
    • Make sure you are careful when moving the logic board. Try to avoid touching the top of the board if possible. Also make sure that if you put it down on top of something that the black plastic is still stuck to the bottom (as shown in the second picture).
  6. Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 步骤 6 中的图像 1,1
    • Remove the screw that is circled in red. This is the screw that holds the mode selection wheel in place.
    • Make sure that you do not lose the metal piece that is located underneath the screw. You will need this to install the new wheel.
  7. Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 步骤 7 中的图像 1,1
    • With the screw holding it in place removed, the mode selection wheel should come right off. Simply remove it from its socket.
结论
Congratulations, you have successfully removed the mode selection wheel from your camera. To reassemble your device, follow these instructions in reverse order.
Mathew Pilozzi
于03/30/15注册
101 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-3, Shastany Spring 2015 UMass Dartmouth, Team 2-3, Shastany Spring 2015 的会员
UMASSD-SHASTANY-S15S2G3
5 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 39
总计 1,194
