跳转到主内容
Canon Selphy CP720 Cooling Fan Replacement
你所需要的
  1. Canon Selphy CP720 Cooling Fan Replacement, Cooling Fan: 步骤 1 中的图像 1,2 Canon Selphy CP720 Cooling Fan Replacement, Cooling Fan: 步骤 1 中的图像 2,2
    • Remove the four 8mm Phillips #1 screws from the bottom of the printer.
  2. Canon Selphy CP720 Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • Gently lift the top half of the printer off its base
    • A data ribbon attaches the two halves, so don't pull hard and keep the two halves close together.
  3. Canon Selphy CP720 Cooling Fan Replacement: 步骤 3 中的图像 1,3 Canon Selphy CP720 Cooling Fan Replacement: 步骤 3 中的图像 2,3 Canon Selphy CP720 Cooling Fan Replacement: 步骤 3 中的图像 3,3
    • Remove the side panel by lifting it out.
  4. Canon Selphy CP720 Cooling Fan Replacement: 步骤 4 中的图像 1,2 Canon Selphy CP720 Cooling Fan Replacement: 步骤 4 中的图像 2,2
    • Unplug the fan from the circuit board by gently pulling on the wire connector at the base of the port.
    • Do not tug on the wires. Slowly increasing force as you pull is the best way to detach the wires.
  5. Canon Selphy CP720 Cooling Fan Replacement: 步骤 5 中的图像 1,1
    • Unscrew the two 8mm Phillips #1 screws from the fan.
    • Remove the fan from the panel.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 310
