跳转到主内容
Canon SX40 HS camera LCD Screen Cover Replacement
你所需要的
  1. Canon SX40 HS camera LCD Screen Cover Replacement, LCD Screen Cover: 步骤 1 中的图像 1,2 Canon SX40 HS camera LCD Screen Cover Replacement, LCD Screen Cover: 步骤 1 中的图像 2,2
    • Open/turn the LCD screen until it fully extends outwards.
    • Remove these two 4 mm black screws on the left side of the screen with a Phillips size #00 screwdriver.
  2. Canon SX40 HS camera LCD Screen Cover Replacement: 步骤 2 中的图像 1,1
    • Partially close the screen and rotate it 90 degrees until the screen is facing upwards (photo view from the left front of the camera). Remove the 4mm black screw, indicated in the picture, with a Phillips #00 screwdriver.
  3. Canon SX40 HS camera LCD Screen Cover Replacement: 步骤 3 中的图像 1,1
    • Rotate the screen 180 degrees until the monitor is facing downwards. Remove the 4mm black screw, indicated in the picture, with a Phillips #00 screwdriver.
  4. Canon SX40 HS camera LCD Screen Cover Replacement: 步骤 4 中的图像 1,3 Canon SX40 HS camera LCD Screen Cover Replacement: 步骤 4 中的图像 2,3 Canon SX40 HS camera LCD Screen Cover Replacement: 步骤 4 中的图像 3,3
    • Using a plastic opening tool, remove the unfastened LCD screen cover from the camera.
    • Be careful not to pry and damage the circuit card under the screen cover.
  5. Canon SX40 HS camera LCD Screen Cover Replacement: 步骤 5 中的图像 1,3 Canon SX40 HS camera LCD Screen Cover Replacement: 步骤 5 中的图像 2,3 Canon SX40 HS camera LCD Screen Cover Replacement: 步骤 5 中的图像 3,3
    • This is what you should see after removing the LCD screen cover. Replace the LCD screen cover if damaged.
结论
2等其他人完成本指南。
John Bui
于03/26/15注册
352 声望
创作了3篇指南
团队
UMass Dartmouth, Team 7-7, Cichon Spring 2015 UMass Dartmouth, Team 7-7, Cichon Spring 2015 的会员
UMASSD-CICHON-S15S7G7
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 1,741
