跳转到主内容
Canon SX40 HS camera Flash Cover Replacement
你所需要的
  1. Canon SX40 HS camera Flash Cover Replacement, Flash Cover: 步骤 1 中的图像 1,2 Canon SX40 HS camera Flash Cover Replacement, Flash Cover: 步骤 1 中的图像 2,2
    • Extend the flash cover upwards and remove the 4 mm black screw located on the left side. You will need a Phillips #00 screwdriver to remove it.
    • Repeat to remove the 4 mm black screw located on the right side.
  2. Canon SX40 HS camera Flash Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the plastic cover using the iFixIt Plastic Opening Tool.
    • The plastic cover can only be removed in the down position.
  3. Canon SX40 HS camera Flash Cover Replacement: 步骤 3 中的图像 1,2 Canon SX40 HS camera Flash Cover Replacement: 步骤 3 中的图像 2,2
    • After removing the flash cover, remove the 6 mm silver screw on the right side with a Phillips #00 screwdriver.
    • Repeat to remove the 6 mm silver screw on the left side with a Phillips #00 screwdriver.
  4. Canon SX40 HS camera Flash Cover Replacement: 步骤 4 中的图像 1,1
    • Replace the external flash cover or the internal flashlight when all 6 mm silver screws are out.
结论
To reassemble your device, follow Steps 1-4 in reverse order.
另外一个人完成了本指南。
John Bui
于03/26/15注册
352 声望
创作了3篇指南
团队
UMass Dartmouth, Team 7-7, Cichon Spring 2015 UMass Dartmouth, Team 7-7, Cichon Spring 2015 的会员
UMASSD-CICHON-S15S7G7
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 795
